K kingtoxik Member Jun 9, 2012 #1 Is there an CRT on/off zip that can be flashed thru CWM into stock rom ??
D Deleted User Guest Jun 9, 2012 #2 kingtoxik said: Is there an CRT on/off zip that can be flashed thru CWM into stock rom ?? Click to expand... No, it requires a lot of changes to the framework.apk.
S shizack Newbie Jun 9, 2012 #3 Check out an app in the Play Store called Screen Off and Lock. It has several off animations to choose from including CRT-style. Only downside is it doesn't work from the power button but you can add a shortcut for one-button display off with animation and sound.
