Root [Boost Mobile] Customize widgets?
UnknownUser1
Android Expert
I have a widget id feally like to keep but its huge is there an app compatible with our phones to edit size color or symbol or anything so its not huge? (If you dont recognize me by now i am a rooted user so any app will do)
Idk of any apps the can edit the size. But a lot of launchers give that option if you long press the widget, so it's up to you if you don't mind another launcher
Desktop Visualizer! Its awesome you can even use this app to my invisible Widgets IMO it rock download it check it out if you do t like it one could always uninstall it :):):):)
I do recognize you. Good to see you again pal. Nice change of pic :)
You need to make a transparent PNG GIF jpg. If don't have access to making one. And really want one ill up load a transparent PNG. I have 12 widget on my desktop and all are invisible
Have you looked into the app yet
How do i upload a pic . The easiest way for me would be email if u pm me your email address I ccan do it that way
Edit give me a bit and I will upnload the png to this thread I figured it out
Edit: once you have the widget were u want it click on it the press the select icon button and then select the transparent pic I uploaded (I haven't uploaded it yet sorry)
Haven't forgot about you its hard to upload from my phone is difficult and my service is shotty if best where I'm staying this weekend sorry friend
finally here is a transparent.png sorry it took so long but if your like me and want widgets but still want to see you backround picture this is perfect
No i really like the launcher ihave nd i dont see many options that are smaller in size and ram but if you have a sugestion im willin to look into it.i have experia at the moment. What do honeycomb things use
Its cool i still use the app you told me about and it works for some things i want but not all so i was gunna keep lookin
