Root [Boost Mobile] Error Mounting SD Card
klishak22
Ok, I have done some research on this issue, and not sure if anyone knows exactly what is going on here. I have a few SD cards from various phones. When I have been using CWM I can only access a certain SD card. The others all say Error can't mount SD card; however, the phone uses the SD card just fine. Only CWM gives me a problem with this. Well, attempting an update on the ROM I'm using my SD card that worked before now does the same error. Any clue as to what is causing this? Any possible solutions other then buying a new SD card? Thanks!
If your running windows 7 and have ever formatted your card via built in format program, it messes it up. I know how to fix this though:, first mount usb storage...make sure u have all hidden files shown, and copy/paste all your entire sd card somewhere on ur pc to back it up...then download this program http://dl.dropbox.com/u/65761686/sdfmt3_1%20%282%29.zip extract the zip, and run it, choose format option erase all. upon format completion, load your files back onto the card, and you should be all set.
