Root [Boost Mobile] flashed wrong rom?
bricky
Somehow I think I flashed a rom not made for the warp (I have the warp) and its working better than the others I've tried. I flashed ics v 1.0.1 its made Samsung and HTC from what I've read.it says something about un rooting,but obviously I'm a little confused.is it safe for thewarp, is it wrong rom? The speed numbers are great with no glitchches with super phone 2 its real quick
just as long as you don't flash a recovery. img i believe you will be OK and won't lose root. but I'm new and don't know the whole deal.
Can you provide a link so I can see what you're talking about
Post a link to the rom. If that rom isn't made for the warp you may have good reason to call yourself bricky.
Or you may have gotten extremely lucky
No I can't find link don't know where I got it from I thought I was flashing warp cream.I've already flashed a different rromom but I want to use it.it worked so good fastest I've had and best connectivity.with speedtest I Avr 150/1500/900 with no oc kernel
Did you download using phone or PC.where ever you downloaded it to :othe link should be there ,SD card or PC downloads.
Can u post the link
Haha... just looked through this and I definately see n860 warp and author in the build.prop.... sooo.... anyone flash it to see if its just one of the roms that's out right now? Possibly just mine....? :-\
Sent from my N860 using Tapatalk 2 Beta-5
