D
Deleted User
Guest
I'm not ready to give up on cm7. Thanks for clearing that up though. Once I get more free time I'll start again. CAF looks like it has potential as far as telephony and ril sources.
Well I should talk with quietstorm to see if we can collaborate to get this done, work has finally slowed down, thank god![]()
but the screen is upside down, maybe a build.prop issue
Im working on porting miui from the thunderbolt to our warp too.
Is it because lgeqcom gsm? Or did you change it to cdma?@down I edited the RIL java files, then used the lgeqcom ril class. It was enough to get sms working, but I still havent figured out how to get it out of roaming... its kicking my ass...
I'm taking a break, got my nam wiped working on cm9, so do yourself a favor, get cdma workshop, make a backup of your nam, just incase something in the RIL goes tits up. I need some time to calm down![]()
I haven't gotten back to it since Quietstorm put up his github. There has been alot of headway. I believe ril is working.
Hey dumb question here but ril is what?
