Boost mobile galaxy s2 unroot
CellBlock420
Hey guys I rooted my boost mobile galaxy s2 (sph-d710bst) using framaroot.apk
Something didnt go right and i need to unroot and revert to stock.
Can someone help me please?
I just rooted my gs2 with framaroot yesterday also!! If you open your framaroot app again click on where it says superuser at the top then select unroot then click on frodo.. This will unroot your gs2!! I tryed the unroot to option and it totally works!! Very easy and only takes a minute.. It removed the root exploit and deletes superuser.. I didnt see busybox in this root method but be sure to get a busybox installer from the play store so you will have it..
Silly question I know but I don't know the answer so I'm going to asked. When you unroot your phone, does that still void the warranty on it? If something did go wrong with your phone would they know it was rooted and unrooted ?
Sorry for the noob question
Flashing it back to stock unrooted is what you do before returning the phone for a warranty issue. You want that flash counter to be reset and to be on stock with no tattletale triangle. if you can't flash back for some reason then you want to have "accident" insurance (hint hint)
hey danielmike. Im glad i saw ur post on here i jst joined recently and was thinking bout roting my phone with framaroot but wanted to make sure i could unroot it also with framaroot. So will boost know it has been rooted if i needed to get a replacment or have to fixed???? I haven't had the phone long and got the insurance on it. Thanks in advance. Also how do i get the file that will unroot?
use the fi22 and go into settings/update now just update your phone
and this will take me back to stock like when i bought the phone??? and so i just flash this in odin PDA rite? also witch odin i use? when i go to the link witch one do i download there is like four of them
