So that update or file gets you complete stock? No root and does it reset knox?I don't want to recommend this method but if anybody wants to try, be careful use on your own risk! Better yet, ask for advice.
Anyway, I want to thank you, your method help me root back my phone with the last update
You did that through recovery? I want complete stock so I can upgrade my phonehttps://drive.google.com/file/d/0B2....com/file/d/0B2JkNe5HpKLHM1M1MnpzN2t4SzQ/edit
The_Dumbest_noob pulled the update zip, that is the latest one. I flashed it using stock recovery or if you prefer to get it OTA.
You can check the Tri-Band S3 (SPH-L710T) page 35
Link stock tar pleaseOnce you are completely stock, boot into stock recovery and flash the update zip, it worked for me
Thanks! What version of Odin did you use?http://androidforums.com/threads/ro...e-all-spt-l710tvpu0anf4-l710tspt0anf4.896195/
Check it out! This is the one I use
Will do I will do it in a bit the only reason I don't want root is because ever since I got this stock root deodoxed "Rom" playing some games I really enjoy fifa 15 being one of them or something like instagram force closes all the time............Good luck! Let me know if it works for you
