just click the zip icon, download the source, go into device folder, create a new folder called zte, then go inside there, create another folder called arthur, then unzip source into there.
where he says to type
Code:
$ lunch full_prevail-eng
instead type:
Code:
$ lunch ZTE_arthur-eng
after doing all that you can follow his directions to a T, and you will have your very own build of ics.
