Root [Boost Mobile] Help With Download Apk
Well, what ROM are you using? You can use root explorer and navigate there then copy and paste to your sd card. Or you can use ADB pull method too.
Well I am using noob which doesn't have the download apk
Ok, All you have to do is go up to the ATR guide and download the rom you want. Unzip it on your PC and extract the apk you want.:D I do it all the time, especially when I need or want a better camera, sms app, etc. :)
But your probably on Tapatalk arent you.:p
