Root [Boost Mobile] I can help with **Warp Rooting,Installing a Rom**
Atrocity
Member
I can help with Installing Roms and Rooting the Zte Warp. If i cannot answer the question i will try my best to find the answer just be patient if i do not respond immediately.
the B08 ROMs are: Unitology, Shinjitsu and Vilano- the B08c ROMs are:WP7, Noob, WCS, Blue ROM, Fallout ROM, Warpshark, and a deal of others hahah
i finally got my warp rooted and im looking for the whole rom. kernel and what ever else i would need. i want the phone as fast as i can get it without too many head aches. my phone is bo8c. also looking for good launcher and good footed apps. thanks
Look for the b08 kernal fallow flash instructions. Then get unitology
superuser it is saying its binaries are outdated but when I try to update it fails. do I need to be concerned
Heres a couple fixes:
1) go to the market search superuser and unistall(no it'll just unistall updates) then go back into superuser and update the binary it SHOULD work then feel free to update superuser :D
2) flash the superSU zip (i would put it up but i do NOT have it :(
Hope that helps
Cheers!
I know this might be filed under the dumb question category but how do you flash something
Download the zip file(not all zips aee flashable) place on sd card boot into recovery scroll to install zip from sd select your zip and select yes and poof! Its flashed
You need to format your sd card for some reason it is not reading it. This can be done in clockworkmod.
I just formatted SD card thru CWM & IT'S still giving me an error. Can't mount SD card. Also when I try mount SD card manually it gives me the same error .. any help ?
I'm trying to install shinjitsu rom. when they say clearcache do they mean wipe cache partition that's the only thing I see. I've installed noob rom
I need my device Ip it has disappeared since I rooted or since I changed roms. I can't use gps or navigation without it it can't find me
