vitalitouch
Member
So im running the Noob rom and somewhere i aquired the ICS Keyboard. I dont remember if it came with this rom or another that i had flashed before i found this one.
Anyway... I have deleted all other keyboards but this one, and i placed this one into my system apps. Everything works perfectly EXCEPT. whenever i reboot my phone, i get a force close popup for ics keyboard. The notification makes my phone basically inoperable as it pops up every couple seconds until i restore my ics keyboard through TB. Then, all is well until i have to reboot again. Any ideas? I did this same method with Swype (my old key board of choice), and it worked fine.
Background info may or may not be helpful:
I dont have TB Pro so i can not make the file a system file through TB. I used ES File Explorer to move the file. I have used it for Zeam launcher, Be weather, ICS Camera + and a few other files to make them system files, and all continue to worked fine, even after reboot.
PPS-
I seldom reboot my phone as my phone runs like hot butter
Thanks in advance for all your brain power
PPS-
on the stock android keyboard i would always hit the period instead of the space bar haha swiftkey3 so far is my favorite keep me corrected and usually knows what im going to type
not easy having a small keyboard with big fingers
