Boost Mobile ID Packs
Trimbaud
So, I just factory reset the Warp again. (I have a work cell on Verizon, and a couple a tablets, so I am much less stressed about this thing crashing more than a drunk Nascar driver). Just for giggles, I was gonna try one of the Boost ID Packs - and they are gone! The icon is in the dock tray, but there arent any IDs to choose from. Did I miss something?
Don't you have to download the ID packs first? Don't really know, never bothered with that feature.
You are correct , you do have to download new id packs . ..
O.K so select and go into your Mobile ID App... Welcome to Mobile ID will appear select continue . The next screen will say "Choose Your ID" select Get New ID Packs. ( You can only select the Manage ID Packs ) when you have installed another ID pack . Hope this helps.
