Sorry to dig up this thread again, but this didn't help me either. I've tried this in call steps option on volume+ and it did zilch. Anyone else have any other ideas? I work with large machines and could do with a boost to my in call volume.
It kinda makes me laugh that Volume+ leaves the line in the build.prop when you uninstall the app so you actually keep the last increment you put in, thus actually keeping volume+ in a weird way. It's a good way for people to edit the line though since they don't actually have to go into the build.prop manually. I think it's why he quit charging for the app because his conscience took hold of him, which doesn't make me laugh and actually makes me proud of him.
no need at all for volume+did not work for meActually current Volume+ versions are not supposed to boost the in-call volume, you can add more steps, but it won't change the max volume, just smooth steps (a useless feature, imho). You can read it in short description of a feature, which is located in a volume+ kernel tweak menu. The only known ways to increase in-call volume - either using a custom kernel with modded audio drivers, or increase the max volume in a "Service Menu" (dial *#*#197328640#*#*), (IT IS ONLY AVAILABLE FOR SAMSUNG ANDROID DEVICES), which has a blocked sound menu in it. You get through that block by entering "5" in "Key input" option and then menu will appear, you have to click (touch the screen):
1. For in-call Ear mode volume:
1 HANDSET - Pay attention
2 RX value
1 Rx Codec/Volume
1 Rx Codec Gain
when "Input value" field appears, press left mechanical key (options key), choose "Key Input" - in a pop-up field enter: ffff and then press OK.
2. For in-call Loudspeaker mode volume:
3 SPEAKER - Pay attention
2 RX value
1 Rx Codec/Volume
1 Rx Codec Gain
3. For Call and SMS sound volume:
7 MP3/Not Mp3 Mod - Pay attention
2 RX value
1 Rx Codec/Volume
1 Rx Codec Gain
Changes persist through Power off and restarts.
Changes are more, than enough noticeable (you will no longer need to max volume setting, it will be a lot louder).
Tested on some non-Cyanogen Gingerbread ROMS, menu doesn't exist on Cyanogen ROMS.
I have not tried to cancel changes, because i like it, but, i think, Flashing new Kernel should do it.
OR
entering default values (they are Hexadecimal, i believe)
OR
(a quote from internets)
in the Service menu > Audio
- 6 REBUILD ALL
- Yes, Press [1]
- have been rebuilded
- Please reboot
