Ok, here are the edits i made to acpuclock-7x30 for OC to work. I could really use some input on why Bluetooth isn't working and what might be causing signal loss when the phone sleeps with wifi enabled.
I have looked the file over 100 times and cant figure this thing out, it doesn't make sense that the OC would cause this. Anyways here it is
Code:
* Copyright (C) 2007 Google, Inc.
* Copyright (c) 2007-2011, Code Aurora Forum. All rights reserved.
* This software is licensed under the terms of the GNU General Public
* License version 2, as published by the Free Software Foundation, and
* may be copied, distributed, and modified under those terms.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
#include <linux/version.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/errno.h>
#include <linux/string.h>
#include <linux/delay.h>
#include <linux/clk.h>
#include <linux/cpufreq.h>
#include <linux/mutex.h>
#include <linux/io.h>
#include <linux/sort.h>
#include <mach/board.h>
#include <mach/msm_iomap.h>
#include <asm/mach-types.h>
#include "smd_private.h"
#include "clock.h"
#include "clock-local.h"
#include "clock-7x30.h"
#include "acpuclock.h"
#include "spm.h"
#define SCSS_CLK_CTL_ADDR (MSM_ACC_BASE + 0x04)
#define SCSS_CLK_SEL_ADDR (MSM_ACC_BASE + 0x08)
#define PLL2_L_VAL_ADDR (MSM_CLK_CTL_BASE + 0x33C)
#define PLL2_M_VAL_ADDR (MSM_CLK_CTL_BASE + 0x340)
#define PLL2_N_VAL_ADDR (MSM_CLK_CTL_BASE + 0x344)
#define PLL2_CONFIG_ADDR (MSM_CLK_CTL_BASE + 0x34C)
#define dprintk(msg...) \
cpufreq_debug_printk(CPUFREQ_DEBUG_DRIVER, "cpufreq-msm", msg)
#define VREF_SEL 1 /* 0: 0.625V (50mV step), 1: 0.3125V (25mV step). */
#define V_STEP (25 * (2 - VREF_SEL)) /* Minimum voltage step size. */
#define VREG_DATA (VREG_CONFIG | (VREF_SEL << 5))
#define VREG_CONFIG (BIT(7) | BIT(6)) /* Enable VREG, pull-down if disabled. */
/* Cause a compile error if the voltage is not a multiple of the step size. */
#define MV(mv) ((mv) / (!((mv) % V_STEP)))
/* mv = (750mV + (raw * 25mV)) * (2 - VREF_SEL) */
#define VDD_RAW(mv) (((MV(mv) / V_STEP) - 30) | VREG_DATA)
#define MAX_AXI_KHZ 192000
#define ARTHUR_ACPU_MIN_UV_MV 750U
#define ARTHUR_ACPU_MAX_UV_MV 1525U
struct clock_state {
struct clkctl_acpu_speed *current_speed;
struct mutex lock;
uint32_t acpu_switch_time_us;
uint32_t vdd_switch_time_us;
struct clk *ebi1_clk;
struct pll {
unsigned int l;
unsigned int m;
unsigned int n;
unsigned int pre_div;
struct clkctl_acpu_speed {
unsigned int use_for_scaling;
unsigned int acpu_clk_khz;
int src;
unsigned int acpu_src_sel;
unsigned int acpu_src_div;
unsigned int axi_clk_hz;
unsigned int vdd_mv;
unsigned int vdd_raw;
struct pll *pll_rate;
unsigned long lpj; /* loops_per_jiffy */
static struct clock_state drv_state = { 0 };
/* Switch to this when reprogramming PLL2 */
static struct clkctl_acpu_speed *backup_s;
static struct pll pll2_tbl[] = {
{ 42, 0, 1, 0 }, /* 806 MHz */
{ 48, 1, 3, 0 }, /* 921 MHz */
{ 53, 1, 3, 0 }, /* 1024 MHz */
{ 58, 1, 3, 0 }, /* 1113 MHz */
{ 63, 1, 3, 0 }, /* 1209 MHz */
{ 68, 1, 3, 0 }, /* 1305 MHz */
{ 73, 1, 3, 0 }, /* 1401 MHz */
{ 78, 1, 3, 0 }, /* 1516 MHz */
{ 83, 1, 3, 0 }, /* 1612 MHz */
{ 88, 1, 3, 0 }, /* 1708 MHz */
{ 93, 1, 3, 0 }, /* 1804 MHz */
{ 98, 1, 3, 0 }, /* 1900 MHz */
/* Use negative numbers for sources that can't be enabled/disabled */
#define SRC_LPXO (-2)
#define SRC_AXI (-1)
* Each ACPU frequency has a certain minimum MSMC1 voltage requirement
* that is implicitly met by voting for a specific minimum AXI frequency.
* Do NOT change the AXI frequency unless you are _absoulutely_ sure you
* know all the h/w requirements.
static struct clkctl_acpu_speed acpu_freq_tbl[] = {
{ 0, 24576,SRC_LPXO, 0, 0, 30720000, 900, VDD_RAW(900) },
{ 0, 61440, PLL_3, 5, 11, 61440000, 900, VDD_RAW(900) },
{ 1, 122880, PLL_3, 5, 5, 61440000, 900, VDD_RAW(900) },
{ 0, 184320, PLL_3, 5, 4, 61440000, 900, VDD_RAW(900) },
{ 1, 245760, PLL_3, 5, 2, 61440000, 900, VDD_RAW(900) },
{ 1, 368640, PLL_3, 5, 1, 122800000, 900, VDD_RAW(900) },
{ 1, 460800, PLL_1, 2, 0, 153600000, 900, VDD_RAW(900) },
{ 1, 576000, PLL_1, 2, 0, 153600000, 950, VDD_RAW(950) },
{ 1, 652800, PLL_1, 2, 0, 153600000, 950, VDD_RAW(950) },
{ 1, 768000, PLL_1, 2, 0, 153600000, 950, VDD_RAW(950) },
{ 1, 806400, PLL_2, 3, 0, UINT_MAX, 1000, VDD_RAW(1000), &pll2_tbl[0]},
{ 1, 921600, PLL_2, 3, 0, UINT_MAX, 1000, VDD_RAW(1000), &pll2_tbl[1]},
{ 1, 1024000, PLL_2, 3, 0, UINT_MAX, 1000, VDD_RAW(1000), &pll2_tbl[2]},
{ 1, 1113000, PLL_2, 3, 0, UINT_MAX, 1000, VDD_RAW(1000), &pll2_tbl[3]},
{ 1, 1209600, PLL_2, 3, 0, UINT_MAX, 1050, VDD_RAW(1050), &pll2_tbl[4]},
{ 1, 1305600, PLL_2, 3, 0, UINT_MAX, 1200, VDD_RAW(1200), &pll2_tbl[5]},
{ 1, 1401600, PLL_2, 3, 0, UINT_MAX, 1250, VDD_RAW(1250), &pll2_tbl[6]},
{ 1, 1516800, PLL_2, 3, 0, UINT_MAX, 1300, VDD_RAW(1300), &pll2_tbl[7]},
{ 1, 1612800, PLL_2, 3, 0, UINT_MAX, 1350, VDD_RAW(1350), &pll2_tbl[8]},
{ 0, 1708800, PLL_2, 3, 0, UINT_MAX, 1350, VDD_RAW(1350), &pll2_tbl[9]},
{ 0, 1804800, PLL_2, 3, 0, UINT_MAX, 1350, VDD_RAW(1350), &pll2_tbl[10]},
/* Values Commented out will be tested at a later date to ensure compatability and stability
{ 0, 1900800, PLL_2, 3, 0, UINT_MAX, 1450, VDD_RAW(1450), &pll2_tbl[11]},
{ 0 }
#define POWER_COLLAPSE_KHZ MAX_AXI_KHZ
unsigned long acpuclk_power_collapse(void)
int ret = acpuclk_get_rate(smp_processor_id());
acpuclk_set_rate(smp_processor_id(), POWER_COLLAPSE_KHZ, SETRATE_PC);
return ret;
#define WAIT_FOR_IRQ_KHZ MAX_AXI_KHZ
unsigned long acpuclk_wait_for_irq(void)
acpuclk_set_rate(smp_processor_id(), WAIT_FOR_IRQ_KHZ, SETRATE_SWFI);
return ret;
static int acpuclk_set_acpu_vdd(struct clkctl_acpu_speed *s)
int ret = msm_spm_set_vdd(0, s->vdd_raw);
if (ret)
return ret;
/* Wait for voltage to stabilize. */
udelay(drv_state.vdd_switch_time_us);
return 0;
/* Assumes PLL2 is off and the acpuclock isn't sourced from PLL2 */
static void acpuclk_config_pll2(struct pll *pll)
uint32_t config = readl(PLL2_CONFIG_ADDR);
writel(pll->l, PLL2_L_VAL_ADDR);
writel(pll->m, PLL2_M_VAL_ADDR);
writel(pll->n, PLL2_N_VAL_ADDR);
if (pll->pre_div)
config |= BIT(15);
else
config &= ~BIT(15);
writel(config, PLL2_CONFIG_ADDR);
/* Set clock source and divider given a clock speed */
static void acpuclk_set_src(const struct clkctl_acpu_speed *s)
uint32_t reg_clksel, reg_clkctl, src_sel;
reg_clksel = readl(SCSS_CLK_SEL_ADDR);
/* CLK_SEL_SRC1NO */
src_sel = reg_clksel & 1;
/* Program clock source and divider. */
reg_clkctl = readl(SCSS_CLK_CTL_ADDR);
reg_clkctl &= ~(0xFF << (8 * src_sel));
reg_clkctl |= s->acpu_src_sel << (4 + 8 * src_sel);
reg_clkctl |= s->acpu_src_div << (0 + 8 * src_sel);
writel(reg_clkctl, SCSS_CLK_CTL_ADDR);
/* Toggle clock source. */
reg_clksel ^= 1;
/* Program clock source selection. */
writel(reg_clksel, SCSS_CLK_SEL_ADDR);
int acpuclk_set_rate(int cpu, unsigned long rate, enum setrate_reason reason)
struct clkctl_acpu_speed *tgt_s, *strt_s;
int res, rc = 0;
if (reason == SETRATE_CPUFREQ)
mutex_lock(&drv_state.lock);
strt_s = drv_state.current_speed;
if (rate == strt_s->acpu_clk_khz)
goto out;
for (tgt_s = acpu_freq_tbl; tgt_s->acpu_clk_khz != 0; tgt_s++) {
if (tgt_s->acpu_clk_khz == rate)
break;
if (tgt_s->acpu_clk_khz == 0) {
rc = -EINVAL;
goto out;
if (reason == SETRATE_CPUFREQ) {
/* Increase VDD if needed. */
if (tgt_s->vdd_mv > strt_s->vdd_mv) {
rc = acpuclk_set_acpu_vdd(tgt_s);
if (rc < 0) {
pr_err("ACPU VDD increase to %d mV failed "
"(%d)\n", tgt_s->vdd_mv, rc);
goto out;
dprintk("Switching from ACPU rate %u KHz -> %u KHz\n",
strt_s->acpu_clk_khz, tgt_s->acpu_clk_khz);
/* Increase the AXI bus frequency if needed. This must be done before
* increasing the ACPU frequency, since voting for high AXI rates
* implicitly takes care of increasing the MSMC1 voltage, as needed. */
if (tgt_s->axi_clk_hz > strt_s->axi_clk_hz) {
rc = clk_set_min_rate(drv_state.ebi1_clk,
tgt_s->axi_clk_hz);
if (rc < 0) {
pr_err("Setting AXI min rate failed (%d)\n", rc);
goto out;
/* Move off of PLL2 if we're reprogramming it */
if (tgt_s->src == PLL_2 && strt_s->src == PLL_2) {
local_src_enable(backup_s->src);
acpuclk_set_src(backup_s);
local_src_disable(PLL_2);
/* Reconfigure PLL2 if we're moving to it */
if (tgt_s->src == PLL_2)
acpuclk_config_pll2(tgt_s->pll_rate);
/* Make sure target PLL is on. */
if (strt_s->src != tgt_s->src && tgt_s->src >= 0) {
dprintk("Enabling PLL %d\n", tgt_s->src);
local_src_enable(tgt_s->src);
} else if (tgt_s->src == PLL_2 && strt_s->src == PLL_2)
local_src_enable(PLL_2);
/* Perform the frequency switch */
acpuclk_set_src(tgt_s);
drv_state.current_speed = tgt_s;
loops_per_jiffy = tgt_s->lpj;
local_src_disable(backup_s->src);
/* Nothing else to do for SWFI. */
if (reason == SETRATE_SWFI)
goto out;
/* Turn off previous PLL if not used. */
if (strt_s->src != tgt_s->src && strt_s->src >= 0) {
dprintk("Disabling PLL %d\n", strt_s->src);
local_src_disable(strt_s->src);
/* Decrease the AXI bus frequency if we can. */
if (tgt_s->axi_clk_hz < strt_s->axi_clk_hz) {
res = clk_set_min_rate(drv_state.ebi1_clk,
tgt_s->axi_clk_hz);
if (res < 0)
pr_warning("Setting AXI min rate failed (%d)\n", res);
/* Nothing else to do for power collapse. */
if (reason == SETRATE_PC)
goto out;
/* Drop VDD level if we can. */
if (tgt_s->vdd_mv < strt_s->vdd_mv) {
res = acpuclk_set_acpu_vdd(tgt_s);
if (res)
pr_warning("ACPU VDD decrease to %d mV failed (%d)\n",
tgt_s->vdd_mv, res);
dprintk("ACPU speed change complete\n");
out:
mutex_unlock(&drv_state.lock);
return rc;
unsigned long acpuclk_get_rate(int cpu)
WARN_ONCE(drv_state.current_speed == NULL,
"acpuclk_get_rate: not initialized\n");
if (drv_state.current_speed)
return drv_state.current_speed->acpu_clk_khz;
else
return 0;
uint32_t acpuclk_get_switch_time(void)
return drv_state.acpu_switch_time_us;
unsigned long clk_get_max_axi_khz(void)
return MAX_AXI_KHZ;
EXPORT_SYMBOL(clk_get_max_axi_khz);
* Clock driver initialization
static void __init acpuclk_init(void)
struct clkctl_acpu_speed *s;
uint32_t div, sel, src_num;
uint32_t reg_clksel, reg_clkctl;
int res;
u8 pll2_l = readl(PLL2_L_VAL_ADDR) & 0xFF;
drv_state.ebi1_clk = clk_get(NULL, "ebi1_clk");
BUG_ON(IS_ERR(drv_state.ebi1_clk));
/* Determine the ACPU clock rate. */
switch ((reg_clksel >> 1) & 0x3) {
case 0: /* Running off the output of the raw clock source mux. */
src_num = reg_clksel & 0x1;
sel = (reg_clkctl >> (12 - (8 * src_num))) & 0x7;
div = (reg_clkctl >> (8 - (8 * src_num))) & 0xF;
/* Check frequency table for matching sel/div pair. */
for (s = acpu_freq_tbl; s->acpu_clk_khz != 0; s++) {
if (s->acpu_src_sel == sel && s->acpu_src_div == div)
break;
if (s->acpu_clk_khz == 0) {
pr_err("Error - ACPU clock reports invalid speed\n");
return;
break;
case 2: /* Running off of the SCPLL selected through the core mux. */
/* Switch to run off of the SCPLL selected through the raw
* clock source mux. */
&& s->src != PLL_2 && s->acpu_src_div == 0; s++)
if (s->acpu_clk_khz != 0) {
/* Program raw clock source mux. */
acpuclk_set_src(s);
/* Switch to raw clock source input of the core mux. */
reg_clksel &= ~(0x3 << 1);
break;
/* else fall through */
default:
pr_err("Error - ACPU clock reports invalid source\n");
return;
/* Look at PLL2's L val to determine what speed PLL2 is running at */
if (s->src == PLL_2)
for ( ; s->acpu_clk_khz; s++)
if (s->pll_rate && s->pll_rate->l == pll2_l)
break;
/* Set initial ACPU VDD. */
acpuclk_set_acpu_vdd(s);
drv_state.current_speed = s;
/* Initialize current PLL's reference count. */
if (s->src >= 0)
local_src_enable(s->src);
res = clk_set_min_rate(drv_state.ebi1_clk, s->axi_clk_hz);
if (res < 0)
pr_warning("Setting AXI min rate failed!\n");
pr_info("ACPU running at %d KHz\n", s->acpu_clk_khz);
return;
/* Initalize the lpj field in the acpu_freq_tbl. */
static void __init lpj_init(void)
int i;
const struct clkctl_acpu_speed *base_clk = drv_state.current_speed;
for (i = 0; acpu_freq_tbl[i].acpu_clk_khz; i++) {
acpu_freq_tbl[i].lpj = cpufreq_scale(loops_per_jiffy,
base_clk->acpu_clk_khz,
acpu_freq_tbl[i].acpu_clk_khz);
#ifdef CONFIG_CPU_FREQ_MSM
static struct cpufreq_frequency_table cpufreq_tbl[ARRAY_SIZE(acpu_freq_tbl)];
static void setup_cpufreq_table(void)
unsigned i = 0;
const struct clkctl_acpu_speed *speed;
for (speed = acpu_freq_tbl; speed->acpu_clk_khz; speed++)
if (speed->use_for_scaling) {
cpufreq_tbl[i].index = i;
cpufreq_tbl[i].frequency = speed->acpu_clk_khz;
i++;
cpufreq_tbl[i].frequency = CPUFREQ_TABLE_END;
cpufreq_frequency_table_get_attr(cpufreq_tbl, smp_processor_id());
#else
static inline void setup_cpufreq_table(void) { }
#endif
* Truncate the frequency table at the current PLL2 rate and determine the
* backup PLL to use when scaling PLL2.
void __init pll2_fixup(void)
struct clkctl_acpu_speed *speed = acpu_freq_tbl;
for ( ; speed->acpu_clk_khz; speed++) {
if (speed->src != PLL_2)
backup_s = speed;
if (speed->pll_rate && speed->pll_rate->l == pll2_l) {
//speed++;
//speed->acpu_clk_khz = 0;
return;
pr_err("Unknown PLL2 lval %d\n", pll2_l);
BUG();
#define RPM_BYPASS_MASK (1 << 3)
#define PMIC_MODE_MASK (1 << 4)
void __init msm_acpu_clock_init(struct msm_acpu_clock_platform_data *clkdata)
pr_info("acpu_clock_init()\n");
mutex_init(&drv_state.lock);
drv_state.acpu_switch_time_us = clkdata->acpu_switch_time_us;
drv_state.vdd_switch_time_us = clkdata->vdd_switch_time_us;
pll2_fixup();
acpuclk_init();
lpj_init();
setup_cpufreq_table();
#ifdef CONFIG_CPU_FREQ_VDD_LEVELS
ssize_t acpuclk_get_vdd_levels_str(char *buf)
int i, len = 0;
if (buf)
if(acpu_freq_tbl[i].use_for_scaling==1)
len += sprintf(buf + len, "%8u: %4d\n", acpu_freq_tbl[i].acpu_clk_khz, acpu_freq_tbl[i].vdd_mv);
return len;
void acpuclk_set_vdd(unsigned int khz, int vdd)
int i;
unsigned int new_vdd;
vdd = vdd / V_STEP * V_STEP;
if (khz == 0)
new_vdd = min(max((acpu_freq_tbl[i].vdd_mv + vdd), ARTHUR_ACPU_MIN_UV_MV), ARTHUR_ACPU_MAX_UV_MV);
else if (acpu_freq_tbl[i].acpu_clk_khz == khz)
new_vdd = min(max((unsigned int)vdd, ARTHUR_ACPU_MIN_UV_MV), ARTHUR_ACPU_MAX_UV_MV);
else continue;
acpu_freq_tbl[i].vdd_mv = new_vdd;
acpu_freq_tbl[i].vdd_raw = VDD_RAW(new_vdd);
#endif
