Root [Boost Mobile] n/a
so I dug this up earlier and I'm thinking about trying.[MOD][RECOVERY] Custom MTD Partitions (resize Data,System and Cache ) [ 2010-10-29 ] - xda-developers
wondering if anyone has tried this yet on our warps?
This will not work on the warp because, the warp uses EXT4 Partitions. If you was to flash this it probably wouldn't do anything because it wont mount the partitions correctly. But, to be on the safe side i would steer clear of flashing that file odds are if it does happen to flash you will brick your phone.
