Root [Boost Mobile] n00bII MIUI Theme
dirtyredz
This is an MIUI style theme I put together for n00bII, Ive re-themed a few apps, added an MIUI bootanimation, Mi Launcher (awesome theme packs downloadable through the launcher!), themed framework-res & more. To achieve the look in the screen shots, open mi launcher themes and download "ANGL" I also dig the falldown transition effects.
Downloadand flash Zip through CWM, and enjoy
Extra included MIUI apps=
Mi Launcher
Compass
Sound Recorder (mp3)
DeskClock
Notes
Stop Watch
Screens;
Download Flashable Zip;
https://www.box.com/s/cd410d6ac6fe65c281fc
Here's the wallpaper
Toggles
Do those toggles in the pulldown menu work...? Cos that would be awesome...
The toggles are from a third party app... they aren't integrated into the system.. but they do work
Sent from my N860 using Tapatalk 2 Beta-5
How come you can't call any one and or is that just me
Not sure how this would effect calling, only changes made were graphics, try restoring a backup and see if calls work. The theme itself is the original n00bII with .PNG files switched out.
I dunno, I have signal. Did you try reverting to a backup and see if it fixes it? Doe's anyone else using this theme have similar issues?
Thanks for helping but I fixed it the thing is I had noob rom 1 and I had flash noob rom 2 and the miui theme at the same time you have to flash noob 2 reboot then go to recovery and flash the miui theme so if any one have the same problem that's how to fix it thanks for the help dirtyredz :D:thumbup:
