Anonimust0704
Hey, I need help choosing a ROM for my warp. I had root it with Easy Root CWM and flashed the Shinjitsu Rom and it worked fine just laggy. So I re-flashed it with the CT Mod Rom and I really like it, just one problem... The in-call volume is to low. I seen a post on there too but it didn't help me out. I've download many many apps to fix it and Volume+ but I don't know how to use it to change the settings? So I researched the problem a little more in-depth and it has something to do with the kernel. The Incall volume quality on stock was perfect and after I flashed it with a custom rom it decreased. I know it was a stupid move to not backup before I flashed but hey I'm only learning. So I kinda want it back to stock rom or if you could at least help me with a rom that has the kernel with the incall volume as it was as it was stock. That would really help me out. I sen the post where the stock rom is posted but I don't know which one to download? And does B10 refer to the baseband version? Cuz mine is one N860B01 and I am really confused. I really appreciate the help :/
