Root [Boost Mobile] New Beats Audio
It makes a definate difference... it made my clock disappear though...
Edit: Never mind this didn't cause it
Sent from my N860 using Tapatalk 2 Beta-5
How can I go back to the original audio?
What do I need to restore?
Restore to a previous nandroid... the zip contained both user apps and system files so you would have to restore both system and data
Thank you, now i can stop fooling with it. But I have a question would it make a difference if we mount system or mount data before installing.
I doubt it... as long as the files are placed correctly they should work either way
