OK.Im wanna use broken rom.n I no its a cem backup so I extracted it in the cwm folder but wen I try to restore it.it says md5 mismatch plz help
Use root explorer go to exstacted click on rom then copy folder to cwm backup.
Redownload the file, its most likely corrupt from the download. I told you this in my thread.
You can't help him if he won't listen sorry, downthemachine. I feel for you
