Root [Boost Mobile] Question CWM
reboot into recovery.. power off your phone, then hold simultaneously the power button and the volume up button.. if it says clockworkmod recovery with a menu above it then your good
The stock recovery has a menu with four options and CWM Recovery has more than four.
Just wanted to help a couple of people out that sometimes are truggling to install the cwm on there phone, go to controlpanel, hardware & sound then devices and update the driver for the warp adb once the software that you are using to install cwm recovery on your phone reconizes the update you should be good reboot your phone to recovery and you should be all set.
P.S Another thing I dont know if it will work for anybody but I took out the micro sd card from the phone and it installed fine on mine hope that this helps anyone.
