esparks004
What option on UOT changed the in-call screen from pink to red? With Red Phone instead of pink?
Alright send me the WP7 framework-res.apk and the systemui.apk and ill update it so it works
good news! i just tested v1.3 i decided to throw a boot animation in there and as it was booting it wasnt doing anything just showing the boot animation then bing! phone is up and running smooth ill be dropping some screen shots in a while and still sorry people the signal bars dont seem to wanna change however i will find a fix for this as soon as possible well enjoy 1.2 for now 1.3 will be here soon and i must say its looking good
I was wondering if I can install this theme while running shinjitsu rom. I installed the theme on my buddies phone and it is awesome. I've had such good luck with shinjitsu I want to keep that but, I would like to have your theme with it, kinda like the best of both worlds thing.
as far as.i know i have the only red theme out so i want to bring it to wp7 and shinjitsu
look forward to itSo guys a few more tweaks to the rapture theme and it will be released for shinjitsu 1.5.1c
no more redeyes ony unitoligy V1.0 its going to be red and black hopefully ill be able to add some pretty cool stuff to it maybe a rotating marker on the pull down notification bar hope you guys will like it
enjoyOkay so i decided to just release the theme now without the signal changes ill rerelease when there.changed look in the op for the linkenjoy
I will download and mess with signal but can't promise anything but you w be first to know, OK.
if it helps when you install the themes it always says installing uot framework so im thinking the signal bars have to be in framework not systemui but its wierd because theres.only 10 images unlike the stock 14 imagesabout to try the theme for the stock rom![]()
The color scheme is a little different for me but I still like it.![]()
