X2 thanks for taking your time to make this work..@QuietStorm1785 Do you have a paypal so i can donate to you? Im more than happy to! You came through where other devs bailed on the warp community. We are all very grateful!
I might make a batch script for installing the cwm for those who can't figure it out and/or are confused and just want a 1 click process if the demand is high enough (about 3 ppl or more)
I'll have to do it tomorrow and/or saturday (gtg in 5 minutes + school tomorrow)
edit: after doing a backup (481 MB on my SD card free), it says in the last lines:
Backing up data...
Error while making a backup image of /data!
What could this mean? Do I not have enough free space?
Did you tested Restore ?![]()
OK n00b question. I have the warp and a prevail I have been too scared to try cwm or anything besides rooting. So the question if one were to try the cwm recovery and not be happy with the results it can be restored to factory with the zte upgrade tool? Right? With the only ill effect being any apps not backed up on the SD card will be lost?
If I should have posted some where else please redirect me to the appropriate place. Just thought this would be an appropriate place being it is a cwm beta release.
Effing n00bs ehh?
Not true. We could make some nandroid backups for people to restore with if they have any issues or highly customized nandroid backups with gingerbread (Replaced launcher/bloatware removed/themed/barebones).Well 'till quietstorm releases his cm7 portI don't think you need the cwm
it only allow custom rom to be installed and other goodies
back 2 ur question..... Yes you can go back to stock recovery
as easy as how you installed the cwm.. The same guide
btw you don't lose anything installing cwm nor going back to the stock...
adb-windows.exe reboot bootloader
fastboot-windows.exe flash recovery stock_recovery.img
fastboot-windows.exe reboot
adb-windows.exe reboot recovery
You also turn on FTM Diagnostic mode from the dialer while in android. Just dial *983*87274# and choose "only Diag". When your done with it you will have to dial *983*87274# again and choose "AT". So there are more ways than one to get to diag mode AKA FTM mode.I personally tested restore myself, and no ftm doesnt work i dont think, I have yet to test it. It didnt work with hroark's build and i doubt it'll work with mine, but you can give it a try
[EDIT]
actually it works, I just tested it while my computer was hooked up to my windows pc, Comes up as zte handset diagnostic interface(DFU) (com9) which is ftm mode.
Thats not true. It doesnt have to be a CM7 rom. Someone can do a backup (nandroid backup) of their phone and share it with you. I would suggest whoever does does a data, cache, and devlik cache wipe first. This way you would have like a new Warp. I dont know why people think CWM is only to flash CM7.Ok I have a problem, I backed up using cwm, then wiped (accidently wiped system) then tried to restore and it says MD5 mismatch, now when I connect to my pc while in cwm I cannot adb in to restore original recovery to ftm and restore original system with zte webupdate tool. Pc dosent recognize adb device. So unless I get a CM7 rom to flash in cwm recovery I am bricked......any help?
This is a bug report.
- Backups dont save user data or restore doesnt restore it. It seems to be there but restore doesnt install it.
- Its to damned dark. Help an old man out and add some light.
