Root [Boost Mobile] [Req]Stock b08 kernal and rom
UnknownUser1
Android Expert
Im looking for the stock b08 kernal for me to reflash but will it data wipe cuz id like to avoid that. And im also looking for stock b08 rom to start building my own rom this weekend if i get the laptop im trying to get can someone help me. And this may be a total nood question but i have to ask as a c.y.a and to make sure i dont cause issues with the rom when i finish it, does cwm need to be put in manualy to the rom or will it stay on the phone regardless or what. Iv seen a few things on making roms and i know i still have more to read before i attempt but i figured i could ask the most important question (due to thats the key to restore and flashing) to make sure i dont cause issues. Thanks in advance for any help
If you look in the stickys for everything root, you'll find stock roms posted by ApolloStar2109. The b08 is stock except a r2d2 boot animation and cwm, and superuser. I'm not sure about where to find the original kernel, i will see if I can find it for you. But no flashing a kernel doesn't require you to wipe data only clear caches
go to the thread "zte warp ultimate drive" Then on the op theres a zip for b08...that is completely stock and if you flash that it will take you right back to the factory version without root or cwm... that's what i use when starting a rom. Has factory set kernel and rom.
Which means that will do a factory wipe and id need to manualy put in cwm and id prefer not to do that and i only wanna flash the kernal to try and fix an issue im having not trying to get rid of the rom im running or anything. But im sure ill end up using it later thank u. Can someone post the b08 kernal with or without boot.img
I already pkan on transfering current to pc then making new on fresh stock possibly using broken rom as a base just gunna be a bit to get the hang of things it wont be anytime soon
