Root [Boost Mobile] [Resolved] stock B08 stock ROM
I could probably make one... it would have to be after I update my rom tomorrow though
Sent from my N860 using Tapatalk 2 Beta-5
to get you started though, here is a post by hroark with return to stock images for the different versions that have come out. I am going to take one of those to go back to stock and run the zte software update tool to see what they are pushing out today, I saw someone claim they are using b08 now and no longer using b08c, but I don't believe it. I will post back results, and deodex b08 for yall and put it into a flashable zip.
http://androidforums.com/warp-all-things-root/521024-return-stock-cwm-updated-4-11-a.html
Whats that B08 file for.? Like to.make a ROM? Or can i use it instead of my B08c stock.? So i wont have trouble right.now trying the Apollo ROM. Lol...just asking.
yes you can flash it to get B08 its just deodexed zipaligned and rooted which UnitologyV1.0A has all of those i will be making a BETA2.5 tonight due to bugs then ill have that tested tomorrow then theme
Okay so i download it then i do what flash it? Im like soooo lost now lol...i wanna try that B08 cuz i dnt want to have trouble >.< i right now im just getting prepaired with TB.
okay B08 really isnt much different then B08c i prefer B08 but yes just flash it its STOCK which is scary to me XD then you boot it up after flash is done then shut it down reboot into recovery install zip from sd and choose the link you recieved last night from Sic Freak
I think ima do it what i had planned...gona boot into r2d2 then clear everything then install from sd card the unitilogy then install update then fix permission then im good...am i right?
