Well Tried other computers, and didnt work. Guess Ill just wait for someone to come up with another root method. Rooting via terminal would be great. But it doesnt look like thats being looked into. Thanks to all for the help.
if you can manage to get cwm in the the rest is a breeze let me think and ill get back to you![]()
Right on, running a zip file in CWM shouldnt be a problem at all. I just cant get CWM on this thing. Got SuperuserZip on my SD. Lol but so far its been useless.
keep trying in the mean time try EVERYTHING
ill get back to you soonhttp://db.tt/1CpnlwRN install to pc then update driver's
You have to click start on pc, bottom left corner, go in controls, then I think manage devices . While phone is plugged in, look for the android, right click on it, then update driver's.
Maybe try pda net
Dont forget to try different usb ports. On my pc the front usb dont work for debugging but the back usb do work. Good luck.
He tried pdanet but it didn't work. Your problem is that usb debugging isn't enabled right? There has been an issue with that not working even after it has been enabled. I had this problem. Sorry for all the confusion or whatnot here. I looked into this thread and see you must be quite frustrated. I am extensively looking into a solution for you.. This is a legit problem if you have usb debugging enabled and you are not seeing the icon. For now my suggestion is to switch your usb ports.
edit: wasn't able to come up with much since i wasnt able to really find anything on usb debugging not working. Mainly unreplied threads or dealing with macs.
In the stock dialer, enter *983*87274#, it will bring up the usb switch test. Press all functions button. Back out of that, then go and make sure usb debugging is on
Dialer pad hidden menu worked. But phone would not go into clockwork. Computer sent recovery, and I waited for the lockscreen before pressing any key. So is clockwork on phone? If so is there a way to go inti clockwork manualy. I know how to do that on the prevail but it seems like its prob dif on this phone. Again thanx to all for the help.
from a command prompt with the phone on type adb reboot recovery to get into it if you have cwm, it probably did install if it sent[/QUOT
Should phone be in boot loader. It didnt work
Got it working, thanks to all fir the help, and for tolerating my frustration.
