StarScream2109
Extreme Android User
Downloading now, about an hour, then ill flash and report by 9:30 hopefully, depends if i can get it to download
Okay sounds good
apollospeed!Follow along with the video below to see how to install our site as a web app on your home screen.
apollospeed!Wooo!!!
Alright the only problem i have so far is there is no web browser, no sirprize cause there hasnt been since i started testing
Quick pic needs updating wont open till you do... no problem there really
Like what needs checked specifically
Gps wifi/3g unknown sources debugging bluetooth
Alright gps works, wifi works, 3g works, unknown sourcez was unchecked but you can chrck it, usb dubugging was unchecked i checked it but i have no way to check and see if it has any bearings on an actual computer. Blutooth works. None come back on after turned off.
Maybe this is nothing but when i flashed this i had the wake issues and flashed that file to make it go away and it said something about flashing a kernal so maybe its a kernal issue cause i have never had the bug
That sounds great. ThanksI would love for you to test as mentioned above contact either me or sic freak via PM and you will recieve a.link![]()
please and thank you for joining this communitysorry did not see the download for the screen fix.... running off little sleep lol
did you get the screen fix?
Yes and think you for your help. So far this is one of the most smoothest Roms I have used so far. I'm looking forward To your next update.
so all in all shes coming along
ill be editing a bit more and themeing ttoday estimated beta3 release is friday!
hope to get it done by today
