cyberone3
Member
My friends say if you use those electronic cigs you can cut back the nicotine slowly so it's a little easier to quit
it depends on the amount you smoke because there is a hard drag on the e-cigs so it take more effort to get the nicotine. so if you smoke alot you may not get enough nicotine to hold you
i know since my parents tried it and failed with them.
the only things that seems to be working is the patch since its a controlled release and no effort
