Smoothkaos
Android Expert
so i got my new device todayloving the touch recovery
beautiful phone and its bigger then the warp
Traitor
No those are V1.0B also guys i will be including the OTA so when i release more versions you will get them OTA
Man, I'm so sick of being the only one to get rolling bootloops everytime I try to run this ROM. I can't even get it to stay open long enough to switch out the build.prop for the one that works. I'm going to try to place the build.prop I copied over to it from my work pc. To be cont.....
The only things in the build.prop are bravia and xloud try removing bravia
Gov pc doesn't have the drivers for my phone and I can't download them because it requires admin rights. I can't get it to stay open longer than 40 seconds past the lock screen appearing to do anything and because the drivers aren't on my work pc I can't mount sd thru cwm. I just cleared cache and Dalvik and reflashed 1.0c and if it doesn't work I'm S.O.L. until I get off work I think. It's my phone, not the ROM, I know. Still pi$$es me off something fierce though because the stupid thing shouldn't be this sensitive to bravia (I always run xloud). I sincerely think it hates b08 because ROM's ran with b08c on it run fine. Bravia wasn't even in 1.0B though I don't think and it didn't want to load either so it's the effin' phone. Oh well, LOL. Hope nobody has anything important to call me about for another 5 hours.
Update:
Nope, doesn't work. I've never had it reboot so quickly before either where I can't even go in and quickly change the build.prop. So frustrated. I'm going to try to find an old PC around here that doesn't have current firewalls so I can get the goddamned drivers and fix it thru cwm.
So reflash and use explorer to go to build.prop and delete bravia itll work great thats what i had to do and after havin issues all day its workin great
Lol thats brutal looks like your waitin till you get home. I had one more bootloop but it hasnt happened again if it does im gunna try and remove the xloud and reinstall beats thru tb
Smoothkaos all you have to do is put the zip on the computer unzip it go to system open the build.prop in an editor edit the tweak out save it zip it back up and flash it
