Root [Boost Mobile] ROM Development for beginners
yankees5963
Do you want to begin developing Rom's for the Warp?
Well, I have put together a .zip file with all the files you need to start developing roms, as well as how to guides.
This zip is 488mb because it has all instillation files and a stock rom, so sorry that the download might take a little longer than expected, but it will have everything you will need to make your rom.
One thing i didn't mention is themeing, to theme just go onto UOT Kitchen then create your custom theme to include in your Rom. When you get a download with your theme, look at the Installing modifications guide to install your theme to your rom, or flash .zip in cwm.
Link to download
http://dl.dropbox.com/u/85786020/Rom Development.zip
Enjoy!
Im gona try and download it on the phn then transfer it to the pc the entire nite >.< hope nothing bad happens >.<
Kind of im using the phn internet for my ipad right now.
well i believe android sdk needs the internet to download some files to install. If you get wifi tether to work, you could use that but it will be slow, if you don't have internet at home your fastest way would be going to like a library with wifi and try installing the software.
Is this it? Cuz i dnt really get it >.< i think ima go to a cousins house and use tthere wifi for a while...just wanted to knw what files are the ones i.need to download.
ohh!!! no need to go anywhere yet, you just need to install java which is in the instillation package, if you have 32bit install java 32bit, if you have 64bit install 64bit then retry the install of android sdk
What if i install both of them? I installed the 64bit cuz it says tht on my laptop
Yupp I just forgot to say install java first. Java is what android is built off of so most things use java. Other then that the guides should be easy enough to make your first rom any questions im here as you know
http://androidforums.com/showthread... change signal bars [edit for easier reading]
