TnTKILLZONE
I agree. That's wayyyyyy too much. But hey, I'm buying a boost iPhone 5c for I believe $450.... and that's at a discounted rate with only 16 gigs of memory.... I really wish they weren't so expensive.. :c
)hey hows it going , i installed the final ROM and i like it it works really well, but theres a message that shows no my screen once in a while it says - Unfortunately, Halo Launcher(prossesscom.mobint.halolauncher) has stopped. - is that normal or do i need an update..
Thanks ...
Flashed it. Seems like you did a good job.
Only thing I am not happy with is the built in tethering isn't enabled.
I prefer to use USB tethering.
Yeah I was never able to figure it out, and since I upgraded my computer from Windows 7 to 8.1 I lost all the files I had taken apart and everything I did to try and figure it out... I never did find out why the built in tethering wouldn't work after a few releases.
My guess is it's either another app interfering with it or Holo Launcher just needs an update. I've never had it before though, but at the same time I haven't use Holo Launcher since I dropped the final of this ROM. It may even be that an update to Holo Launcher is causing it...
Welcome to HaloBean ROM!
A Jelly Bean styled ROM based off Android 2.3.5, HaloBean (originally Halo Jelly) is the continuation of BLVCKHVLO's Halo ROM that is designed to combine looks, performance, and features.
DISCLAIMER: Neither I (Skinnyjeans21) nor BLVCKHVLO (the original creator of this rom) are responsible for any damage, bricked phones (hard brick or soft brick), data loss as a result of not backing up data properly before flashes, or thermonuclear war as a result of flashing this. YOU (the user of this rom) are hereby responsible for anything that happens to your phone after flashing this. Besides, I usually test things myself before releasing for others to test anyways unless I have a broken USB Cable or something.
FEATURES
B10g based
Debloated and odexed
Latest updated Playstore
Camera ICS
Flashlight HD
Quickpic
Themed AOSP Calculator
SuperSU
Voltage control
Alien Kernel by Dm47021
64 ZRAM
SD Read ahead, set to 2046 (always got the best results)
Paranoid Android Live Wallpapers
LMT Launcher (Recent apps doesn't work in this, but its been added as a shortcut in notifications anyways)
Apollo Music Player
CRT on/off
Swipe-to-clear
JB style notifications panel
Lidroid toggles
Modified settings menu: integrated quickpanel settings and shortcuts to edit hidden menu items without the need for MSL.
Adreno 205 GPU tweaks (HUGE MASSIVE thanks to Dizzle1 for finding it, benchmark in next post)
Heavily JB themed (that means:ICS/JB style lock screen pattern and clockBeats+MegaBassBeats+xLoud+ALSA
ICS/JB style sliders and progress bars
JB themed status bar
ICS style notification icons
Roboto font
ICS/JB style toast notifications
JB Transition Animations
JB Notifications in Notifications Panel
ICS/JB Pattern Lockscreen W/ Reduced Slider Path Thickness
And More!
Bravia Engine
Extra volume steps
Wi-Fi/USB Tethering Enabled in Settings
JB Clear Button
No AM/PM in status bar clock
Built-In Ad-Blocking (Mother-Of-All-Ad-Blocking)
Modified MMS (thanks Merc!)
Circle Alarm (Holo Themed)
And most of the included apps are uninstallable if you don't want them, so you can just remove from the applications manager in Settings
Instructions for flashing:
1. MAKE A NANDROID BACKUP BEFOREHAND
2. Download/ save zip to your Warp's SD card
3. Reboot into recovery mode
4. Install/ flash zip from SD card and locate the file
5. Clear cache/ dalvik cache
6. Reboot phone
7. VERY IMPORTANTCome back here and hit the thanks button
TIPS
If you're in Voltage Control and your settings won't stick after a reboot, its because you never saved the settings. To save, set your values and apply. Then press the menu button on the phone and tap "save as init.d script" to overwrite the preincluded settings.
If you're experiencing bad battery drain, try calibrating. This is a rom that you MUST calibrate the battery on. There are several ways to do this, the easiest of which is by downloading an app called Battery Calibration from the market. Follow the instructions within the app (charge to 100%, press calibrate, drain til the phone dies, charge to 100 without break while phone is on, and done, or you can drain again and charge to 100 w/o break and drain and charge 2 or 3 more times to really calibrate it). This does not increase battery life, but gives you a more accurate reading of what the percentage really is, which from my tests is ALWAYS much higher than the phone says when not calibrated.
As mentioned before, most of the apps I have made user apps, so if there are some you don't need, uninstall them as you normally would through the app manager in Settings
Screenshots and changelog are included in the second post of this thread as well
DOWNLOAD
OLD RELEASES
Version 1.99 (Initial release of continued version)
Version 2.75 RCI
Halo Jelly ROM 2.75 RCII
Halo Jelly ROM 2.80
Halo Jelly ROM 2.90
Halo Jelly ROM 3.00
Halo Jelly 4
Halo Jelly 4.2
Halo Jelly 4.3
HaloBean 4.4 (CAUTION: NOW WIPES DATA AGAIN TO AVOID USER ERRORS)
HaloBean 4.47
HaloBean 4.48
HaloBean 4.50
HaloBean 5.0.4
HaloBean 6
HaloBean 6.2+Hotfix/ Update to HaloBean 6.3
HaloBean Seven
HB7 HotFix (FLASH RIGHT AFTER FLASHING 7)
HaloBean 8
LATEST RELEASE
HaloBean 9 FINAL RELEASE
Comments, suggestions? Post 'em here!
Issues or concerns? Those go here too! Others may be having similar problems too, so I ask that questions and such not be sent via PM, only through this thread for open discussion. Also, if you want to use parts of this rom (such as theming) for your own rom or for personal modifications to your rom, that is fine, but if it is released here on AF or anywhere else, remember to give credit for it! Plagiarism is one of the things that really grinds my gears and I don't take lightly to it.
Enjoy the ROM!
Umm... How do I setup multitasking to look cool like in the pic? The ROM is great btw!
Thanks! It's nice to see that people still use it even though I've been really inactive lately.
By multitasking, do you mean the Pie Launcher?
Hey how's it going , haven't been here in a long while. We'll I have a big problem old phone ate wrap n860 stopped working after I added the ROM, I did all the clearing and stuff right deleted everything since google+ had my contacts an all. The thing that happened was Bluetooth stopped working it freezes after it was selected and the sound stopped working properly. So I got another phone instead .. My question is can this problem be fix .? also I took superUs out and unrooted it nothing worked...
Can You Please Re-upload this? link is broken again Thx i was looking fro some new roms to play with but most on here also have dead links.I wish they were all in a torrent or zip file. looking Forward to checking it out THX
