octos has been upgraded to 6.0.1 http://forum.xda-developers.com/galaxy-s3-sprint/development/rom-team-octos-oct-l-t3033797
I'm interested in trying octos. The original post in this thread indicates that we should use the d2bst version, but I'm not seeing that in the Weekly Builds page. What am I missing? Thanks.
No problem I tried to pm you but it wouldn't let me.
Any suggestions on a minimalist rom that works on the SPH-L710T?
No rom I try works.
Most builds are for the 710 not 710T.
Please see a copy of my post below from the main forum.
Sprint
Samsung Galaxy S3
SPH-L710T
KitKat 4.4.2
Baseband L710TVPU0ANF4
Stock Image
This phone is the triband model and not the standard 710.
This model also appears branded and sold by Boost Mobile.
The stock rom on this handset is bloated and slow. I just can not stand using it. I want to install a custom and more minimal rom such as Carbon or CM10 or CM11.
The problem is most custom roms were designed for the 710. The 710T has incompatibility issues because the modem and bootloader appear to be different than the 710.
I can install most of the custom roms that are made available for the non-triband model. The problem is the radio doesn't work. The phone can not register on the network because there is no working modem.
I have tried flashing the NF4 radio after installing a handful of custom roms but the modem functionality doesn't appear to return. And the baseband information will display as unknown. Each attempt forces me to flash the stock 4.4.2 build to get the phone working again.
Does anyone have any working suggestions on how I can dump this stock rom and place a more minimalist working rom on the SPH-L710T? Or have I painted myself in a corner by buying the triband model instead of the standard non-lte model?
I have reviewed the other thread that covers known working roms for the SPH-L710M. But I am not clear on the steps to make them work. I tried installing CM11 and flashing NF4. No success.
I have tried CM10, CM11 and Carbon roms. But most of these roms were designed for the 710. The radio doesn't work. I have tried flashing NF4 after installing these roms but still I get no radio. I always have to revert to the stock 4.4.2 build which is SamBloated in order to get the phone in a usable and working state again.
No rom I try works.
Sprint
Samsung Galaxy S3
SPH-L710T
KitKat 4.4.2
Stock Image
MODS.....PLZ REMOVE OR EDIT THIS POST...this info is incorrect and will cause someone alot of problems and head ache
if your phone is screwed or you want to get back to stock let me know ... or ask for help in here
or pm me
PM me to clarify what info is incorrect, thanksMODS.....PLZ REMOVE OR EDIT THIS POST... MODS.....PLZ REMOVE OR EDIT THIS POST...
or pm me
Does this apply to boost mobile users too? If so, do you have a link to this fix. I've basically given up on custom roms on this phone because I can never get data workingYou can flash any ROM built for the standard l710, on the 710t. You just need the modem firmware symlink fix. Then data will work fine.
All of that flashing is soooo wrong. Dude....
And what do you mean you have philz in bootloader? You seem to have flashed so many random things. I can help you if you want. All of that can be simplified by a lot.
Yes I do, let me look around.Does this apply to boost mobile users too? If so, do you have a link to this fix. I've basically given up on custom roms on this phone because I can never get data working
Did you try the second dirty flash method I came up with? After you flash rom and apn fix, (don't know if there is a ringplus one) boot up then dirty flash just the rom without any wipes. Might work to get lte working.Hello again. Just switched to ringplus for my cell service. It's free! you guys should check it out. Anyway, I went back to stock for the switch because dialer codes never seem to work on custom ROMS. Everything worked well on stock. As soon As I put a Rom on I don't get 4G. 3G yes, but no 4G. I've been running Android Ice Cold Project for a awhile. It's Marshmallow, and there is no place to update profile, PRL update, or APN settings. I've tried toggling Airplane, the APN fix (broke it worse), and other things. Can't use the ##72786# because it's not the stock dialer. I have the SPH-710. Can someone help please? Is there a way to perform an update without ##72786#, or can I use a different dialer app? As always, thanks to all the Dev's out there.
ok thanks for the infoIt works on any 4g enabled, non tri band phone. But since Sprint switched to tri band you can no longer do simultaneous talk and text until they upgrade their system to support VoLTE
https://en.m.wikipedia.org/wiki/Voice_over_LTE
(the T in your model number is for tri band)
