D
Deleted User
Guest
Does anyone know how to mount a sd-ext partition? On the prevail, i had used a modified darktremor app2sd. I think the prevail had an option to mount sd-ext in cwm. Both the warp and prevail i used cwm to partition the sd card, but i didn't see that option to mount it on the warp. Anyways what in trying to do get swapper to swap to ext. Worked great on the prevail. I'm a little lost on what i should look into
