mholloway
Android Expert
sd maid pro is a must have app,its the best phone cleaner in my opinion,you can clean apps ,clean system,and even find all your duplicated files,and you will be amazed how many you have,i use 1 tap cleaner pro,and sd maid still will find stuff in cache ,give it a try ,i used sd maid with shins oc kernal then did the antutu test and got a 4452 score.
very useful app
