Root [Boost Mobile] SimpleROM 1.1
Status
Not open for further replies.
P
PattF
Guest
I thought I would share my personal ROM with you all. It's rock solid, I made it to be light and fast. It's based on B08C.
Features and Improvements:
-Root
-Everything up to date
-The amazing Glitch OC kernel (thx to downthemachine)
-Zram
-Flashlight fix
-Deodexed
-Google proxy servers
-init.d support
-ThrottleService removed
-Extended shutdown menu
-Automatic zipalign
-Common system changes pre-configured
-Launcher Pro
-De-branded
-ALSA!
-XLoud audio system
-Beats Audio
-AOSP Mms app
-Stock tethering menu added to Settings (USB only for now)
-User Agent switching added to Browser
-QuickSettings toggles (thx to MrBoBo)
-Swipe to dismiss notifications
-Better data fix
-WVGA@12Mbps mod added to camera (using H264 under custom)
-Working WiFi tether app added.
-CPU rendering disabled
-Swype keyboard
-Boot image/animation
I've also included a version without Beats/XLoud/ALSA for those who wanted it.
Installation:
1-
2-Reboot to recovery
3-Make a backup
4-Format Dalvik Cache and Data (Only dalvik cache if updating)
5-Flash via recovery
6-Reboot and enjoy!!
Please take note that on the first boot it might be unresponsive for the first 30 seconds or so once you get to the homescreen while it runs through some post-install scripts. Sorry, it only happens the one time. After that the speed more than makes up for the inconvenience.. :)
I also want to say thank you to hroark13, shinru2004, downthemachine, and all the other developers. After working on this for the last month or so I can say it is very hard keeping things stable while adding features. You all have turned this phone into a monster.
1.1
Updated all apps
Moved to SuperSU
Latest Glitch kernel with my edits
Zram
A lot of theme work
Built in ad-blocking
Added a flashlight app
1.0
Switched to google's proxy servers
New boot image and boot animation
Added sound for boot animation
Cleaned up system a bit more
Updated kernel
Updated apps (Swype setup will start on first boot now)
0.2.0
ALSA soundsystem added for a HUGE sound improvement, this+beats=awesome sound
Data fixed on kernel level, script removed
New splash, proper boot animation, wallpaper
Download UI added back, sorry about that.
Music updated
Jellybean fonts
0.1.9
Added Glitch OC kernel
Disabled CPU rendering (UI speedups)
Changed keyboard to Swype
Added splash image and boot animation
Cleaned up build.prop and added some network tweaks
Updated YouTube(1,000,000x better)
0.1.8
Added a framework mod for 12Mbps video recording
Added working WiFi tether app
Testing new approach to Browser UA
0.1.7
QuickSettings toggles added (thanks MrBobo)
Swipe to clear notifications added
Even more theme stuff
Mms app set to dark theme by default now
WVGA modded camera added
0.1.6
Updated su/busybox and stock apps
Removed the Amazon app store to save space
Added AOSP Mms app
Added tether menu to settings
Added User Agent switching to Browser settings under advanced
Changed Browser homepage to Google
Cleaned up the theme quite a bit
Removed "Network Settings" section in the Wireless settings until a fix is found. It force closes on all ROMs.
0.1.5
Updated Superuser and su binary. The new Superuser app now contains most of the SuperSU changes.
Removed The Volume+ app. I didn't realize it was a paid version.
Added XLoud and Beats audio to make up for Volume+ being removed
Changed wallpaper
Stole some ICS ringtones from my tablet
0.1.4
The screen wake problem is confirmed to be fixed now
Removed carrier ID from lockscreen
0.1.3
Reverted kernel to fix wifi
Stopped tools from mounting when connected to USB and removed files
Switched to Launcher Pro, I wanted something that could hide apps and zeam was acting odd
Added Download Crutch so we can download any file
Set up some of the options in the system and Launcher Pro (haptic feedback off, unknown sources on, removed homescreen icons, 1 dock bar, etc..)
0.1.2
failed
0.1.1
Fixed issues with the screen when waking up (Thx ApolloStar2109 )
Removed SQL optimize script that interfered with Root Explorer
0.1.0
Fixed signal bar
Updated init.d files(forgot them in the last release)
0.0.9
Removed throttle for good
Added Shutdown menu
Tweaked theme(added wallpaper, fixed colors a bit)
0.0.8
Broke wifi, removed 3G tweaks.
0.0.7
Updated to shinru2004's non-oc kernel and added speed tweaks for 3G.
trying this out right now
of course as soon as i download it you update it....ill download that too X)
I put that up for you as fast as I could hoping you saw it before you installed. lol I should have done all of this earlier but, well... Double XP weekend.
It's pretty close to stock but give me a few minutes. Most of the changes are under the hood.
The only difference between 0.0.6 and 0.0.8 is shin's kernel which you can get Here if you don't want to download the whole thing. Sorry about that.
New update, now with a permanent solution to the throttle. Still completely stable. Enjoy.
Thanks man, I'm just trying to get the most out of my phone. All the problems with this phone were in shoddy coding, I'm trying to fix that for myself and others.
And thats what.makes a good developer but hey im still relativly.new :D but im a whole different dev i dev with the phone no computer
Status
