slymike123
Member
I don`t know if this is a root question or not but I am rooted with stock rom. On some web sites I can not play videos when on wifi but when I switch to 3g they play, is there some way that I can fix this.
Have you tried installing flash player? Not sure if that'd help or not, I know it helped more videos play on my phone.
Since they play over 3g but not wifi I'm thinking its probably an issue with the routers firewall settings...have you tried over different wifi networks or only just one?
I have only noticed it at home. verizon fios
What about other devices? PC, laptop? Do they stream video over that connection?
Have you accessed the wifi's settings page through a browser? I know some devices need special permissions in order to pull more bandwidth (like streaming video)...especially with mobile hotspots and such...other than that I can't think of anything else to try
I have dolphin and the stock browser just looked through the settings did not see anything for permissions.
The routers settings...
Using your PC or laptops internet browser go to http://192.168.1.1 and when prompted enter your username and password...this will open the routers settings page. Just check through the various settings in basic and advanced security settings to be sure there isn't something that could be blocking your warp from streaming video.
