Heyy guys I'm having a little trouble installing the stock gallery apk I used root explorer and set permission and rebooted and such and still won't show up any help? Thanks guys
Thanks a lot man! But it's for my galaxy rush it's rooted and running clockworkmod it can't wipe or do fix permissions yet since it still needs the recovery img it's still in beta but I'll see if it'll work thankYou
How do you do that? I am gonna just delete reboot set it again reboot wipe cache dalvik then fix permission and reboot to see if it'll work thank you for your time it means a lot!
One of two ways...first is to just tap the app on your sdcard and it should ask if you want to install (make sure install unknown sources is checked in settings) second is to copy apk to /data/app and reboot
