Root [Boost Mobile] Stock ICS Development
yankees5963
Hey, I'm setting up ubuntu virtualbox to compile ICS for the warp. I really want stock ICS to build roms from, not cyanogenmod 9 (ICS). Is anyone else working on this? It would be stupid to start when its already in development.
As far as I know no only 2.3.6 cm7 and cm9
I have found an ics system dump from zte and the phone it is meant for is very similar to our warps... I have had trouble getting it to boot though
Edit: btw... Its 4.0.3 and I also have the kernel which is 3.0.8...
Sent from my N860 using Tapatalk 2 Beta-5
Can you give me a link to the dump? Im going to try to compile ICS in ubuntu for the warp, but since nothing is easy with the warp, I believe its not gonna work fully, so imma try to port the dump if it doesnt work.
It didn't boot... I assume that we would need to some work... is there anyway to run a logcat before booting?
Edit: here are links to the files if anyone wants them
http://www.zte.com.cn/cndata/mobile/software/201205/P020120509526247621205.zip
http://www.zte.com.cn/cndata/mobile/software/201205/P020120525414833367651.zip
The first was the original update that took it from gb to ics... and the second is another update...
Here you go... its an entire update package... just delete the recovery and repackage the system and kernel with hroarks installer template....
And when you did that it wouldn't boot?
