I need 1 as well please keep us posted if you get 1 - i'll do the sameDoes anyone have a stock recovery IMG for the warp?
Ok, obviously you all are not understanding what is being asked for.
This stock recovery img is INCLUDED with the cwm one click if im not mistaken..
Its included in the one click
Or If you give me about an hour I can go home and upload it![]()
UPDATE:
Found a port it would communicate with. So now need to get stock recovery img so I can get ftm mode back so I can put it all back to stock.
Have stock recovery back now so I can put it in FTM mode (which is the only mode QPST will communicate with it in)....
But the handset update tool will not communicate with the device even in FTM mode. I must be doing something wrong.
EDIT/UPDATE::
Had to manually update the FCU driver so now all seems to be working.
Again, thank you so much for posting that img file. I know I'm not the only one who was in need of it.
same problem here - how did you get the driver? - i got FTM mode but handset update tool keeps saying the phone needs to be in FTM mode ... help me please...
EDIT:
I got it now. It's a driver issue for sure (I'm running Win7 64bit) because i connected it to a different laptop (XP Home) and it worked.. Thank you everyone!
Win7x64 doesn't like the drivers it seems. I also have WIn7x64 on my laptop. I had to manually navigate to the ZTE driver folder that the handset update tool created in Program Files and update it that way. Then it worked just fine.
how do i use this file
