Root [Boost Mobile] Stock recovery keeps overwriting clockwork mod.
limited
I've done some searching but haven't seen anyone with this problem. When I flash clockwork mod to my phone it takes and allows me to boot into cwm. However after I boot back into the phone and reboot into recovery it has been replaced by the stock recovery. I'm on B08c.
I don't think that is possible, Your problem is probably that your actually not getting clockwork installed it just says you are.
Oh its installing. I can boot into it right after it is flashed. I installed super user.zip from within cwm. As well as cleared the battery stats and cache. The problem happens when I allow the phone to boot then reboot into recovery its back to stock.
There is something that runs upon startup of the phone that does this... I forgot which file and what exactly needs to be done to fix it... but yeah... you aren't the first to have this problem
Sent from my N860 using Tapatalk 2 Beta-5
Install-recovery.sh remove it
