Root [Boost Mobile] stuck in a boot loop
what exactly was you trying to do but most likely you will have to reflash back to stock or find a rom with root already and flash either way you gonna have to flash i hoped i helped you.
First question that should have been asked is.. Can you get in to CWM? Hold volume up and power at the same time. If you can do that we can help you out. Otherwise it may just be a lost cause.
