Root [Boost Mobile] Tethering
galaxyesm
hello...im getting this problem and idk what to do.
If anyone is also getting or not ill lile some help if possible >.<
How do i knw if its working righr or not? :o
Are you using supersu or superuser. if your using superuser try updating binaries even if its up to date. it will say checking for root and will either say passed or failed. and if your using supersu try running another program that uses root such as titanium backup.
Superuser the greenone and also i did u TB and it works great. Ill check for update
Lol, no the tether, looks like wifi tether for root users. You're not running a oc kernel correct? And your Wi-Fi normally works correct?
Google wifi tether for root users beta. In settings there is a option for device profile. Give that a try, play with those settings til you get a profile that works. I personally use pdanet, its a USB tether
Iv tried 6 wifi tether apps the only one that works is baracle and it works well i wouldnt waste time with others. Wifi for root will broadcast but you wont actualy connect and foxfi will most likly freeze your phone just stick with what works
