Root [Boost Mobile] (Theme) Ice Warp Sandwich
This is my theme for the B08 stock ROM that is supposed to give your phone a more Icecream-like look and feel. This is my first theme ever so i cant really give much help with any problems. Remember that this is my first try, and i will improve the theme as much as i can with UOT and this first version might not be perfect, but i will try my best.
(I will upload an HTC Sense-like theme too very soon for those of you that like Sense)
Changes:
-Top icons on status bar (WiFi, Battery)
-Glowing menu messages are now ICS blue
-Lockscreen has a ICS blue theme
-Loading sign/animation is now an ICS blue radar sign
-ICS colored notification bar
-ICS font (Roboto)
-New Honeycomb-like boot animation
Will be changed soon
-Overscreen glow will be blue (Will update tomorrow)
-Notification background will be improved
USE AT YOUR OWN RISK, I AM NOT RESPONSIBLE FOR ANY DAMAGES DONE TO YOUR PHONE
BACKUP BEFORE INSTALL
Installation
-Place the zip file on your SD card
-Boot with CWM recovery and select "install zip"
-Choose the UOT zip you downloaded
-Reboot phone and enjoy!
Version 1 Download Link:
https://www.dropbox.com/s/6asrmmf0rqxnvyk/UOT-05-13-04-11-2.zip
Attached are some pictures to give you an idea of what the theme looks like (Widget and launcher etc not included)
Also Used in the Screenshots
-DXHome launcher with ICS theme
-Fancy Widgets ICS theme
BUGS:
-Notification icons wont show 3G icon (3G still works, its just the icon)
-Mobile signal icon turns green instead of blue
Question... does the dx launcher give you any problems adding widgets?
Sent from my N860 using Tapatalk 2 Beta-5
