D
Deleted User
Guest
Here is the first theme that I published. It's title is a work in progress
Rethemed:
Status bar and Icons
Notification pull down
Scroll bars
Lock Screen
Loading Icon
Font
Boot Animation (Still has the stock sound though)
pop up power off menu
font changed, though might update to a font that is a little easier to red
And...... The New Signal Icons in the status bar! If anyone is having trouble making that work, pm me. I have a workaround, UOT doesn't put the files in the right place, or name them correctly.
I am also including a stock theme, so if you want to flash it back to stock. Instructions are the same. Although right now, it doesn't flash the stock boot animation, but i'm working on that.
Disclaimer:
I am not responsible for any damages that may occur. You are flashing themes at your own risk.
MAKE SURE YOU DO A NANDROID BACKUP IN CWM!!!!!!!
Instructions:
1. Download Simple Blue.zip
2. Reboot into Recovery
3. DO A NANDROID BACKUP
4. Wipe /cache partition, answer "yes"
5. Go to Advanced Menu, then Wipe dalvik-cache, answer "yes"
6. choose "install zip from sdcard"
7. choose "choose zip from sdcard"
8. locate your file Simple blue.zip in SD
9. confirm "YES - install Simple blue.zip"
10. wait for script to finish
11. reboot phone
Theme Files:
Simple Blue v1.2 different font
Simple Blue v1.2 Font Change.zip
Simple Blue v1.1 (zip says v2)
simple blue v2.zip
Simple Blue:
simple blue.zip
Stock (does not replace bootanimation):
Stock.zip
Fully Stock theme(with original Boost Mobile bootanimation):
new stock.zip
Screen Shots:
see posts below
Version History:
coming soon
Rethemed:
Scroll bars
Lock Screen
Loading Icon
Font
Disclaimer:
Instructions:
11. reboot phone
Theme Files:
simple blue v2.zip
Simple Blue:
simple blue.zip
Stock.zip
new stock.zip
Screen Shots:
see posts below
Version History:
coming soon
