i2f
A Noob's Warped Sandwich (aka Warped Sandwich)
Supported Roms: N00b (8.0-8.2), CTMod-n00b'ed (3.75)
This is a professional, minimalistic theme that combines the best features of the Warp Cream Sandwich Rom (Jetx2x), the Noob Rom (MrBobo), the Warpin' Blue theme (Croy2007), and the ICS Black theme (BlackStar) - along with a few of my own tweaks and changes.
Please select the appropriate version:
N00B
CTMOD-N00B'ED
Thank you for checking out this theme. I really hope you enjoy it!
Hit the thanks button if you like my work!!! You know, to keep me motivated to update these themes.
_____________________________
POSSIBLE BUGS?
To start, I absolutely want people to report any bugs that they think are theme related. I am not perfect and will admit that there may be some bugs in my theme. However, please read the following before reporting them.
This theme does NOT affect performance, as I have only replaced and edited images in various system files. Testing is done intensively before it is released. Also, if you believe that there is a bug in the appearance, first uninstall the theme with the appropriate uninstaller provided above and compare it to the stock appearance. If the issue persists, then it is NOT theme related. In either cases, you should clear the dalvik cache and cache partition in CWM or TWRP and contact MrBobo or Bloodawn for support.
UPDATES?
Because of circumstances, I can no longer update Warped Sandwich for the ZTE Warp. Unfortunately, this means that I cannot update the CT version to be compatible with the latest version of the CTMod rom. If you are looking for an ice cream sandwich theme for the rom, I highly recommend the Touch of Ice Cream Jelly theme by Skinnyjeans21. It was a pleasure sharing my theme with this community. I hope you all enjoyed it as much as I enjoyed making it.
N00B
7.0 FINAL*: Edited status toggle icons, radio buttons, revamped mms.apk, and other notification icons
*After flashing, please go to exDialer, click on menu, and then apply the "Black ICS" theme. It is recommended, but not required, that you go through the app settings to disable "Open Stock Dialer." I have included Modoohut's root patch for missed calls.
COMPLETE CHANGE LOG[Hide]
7.0 FINAL: Edited status toggle icons, radio buttons, revamped mms.apk, and other notification icons
6.0: Compatible with latest update for the N00b Rom (8.0-8.2). Changed unknown contact image. Please note that the systemUI.apk in this theme is not compatible with UOT Kitchen.
5.0: Recolored the number dials in the phone.apk back to white, made transparent the contact badges, added signature to boot screen, included exdialer and dialer theme*, included the LED fix provided by MrBobo, and other minor changes and bug fixes
4.0-4.1: Recolored checkmarks, add input, and text dot to blue. Changed boot animation, check boxes, default wallpaper, loading spinner, thumb quick scroll, low battery image, expander icons, pin lock screen, password lock screen, and number dials in phone.apk. Fixed 1x, 3G icons in status bar. Other minor bug fixes and changes.
3.0: New boot animation, changed loading spinner, new system settings menu, new sync icons, edited thumb slider, darkened keyboard buttons for pin lock screen, changed default contact image in mms and framework, and other minor changes and bug fixes.
2.2.0 - 2.2.0.1: Edited spinner images (looks more minimalistic), edited divider lines (no more white dividers with black backgrounds!), minor bug fix
2.1.0 – 2.1.3.0: Modified checkboxes, radio buttons, and loading spinners, recolored status images (silence all, vibrate, notify more), edited mms.apk, and fixed bugs.
2.0 - 2.0.5: Recolored and modified scroll bar, system status icons (phone, mute, headset), green emergency phone call icon in the lock screen (white), activity and bottom bar from framework and various other apps (AccountAndSyncSettings.apk, Contacts.apk, PackageInstaller.apk). Themed Phone.apk. Removed orange highlight from Google search. Made toast frame more transparent. Removed over-scroll highlight.
1.3.0: Darkened power options icons, made the unlock and ringer icons in the lock screen fully transparent (you can still swipe left and right to perform the functions).
1.2.0 - 1.2.2: Changed color of border and shade for popups, fixed black text issue in notification, added Noob VI's animations (optional, separate download link), fixed thumb slider image, changed to blue spinner (only on black background)
1.1.0: Removed outline of slider (e.g. lock screen, call screen), removed transparency of bottom notification pulldown bar
1.0: Initial Release[/Hide]
TAKE A TOUR OF THE THEME! (screenshots)
DOWNLOAD:
Warped Sandwich Nb 7.0N (No animations from the N00b Rom)
Warped Sandwich Nb 7.0A (Animations from the N00b Rom)
Warped Sandwich Nb Uninstaller 1.0* (Return to stock N00b appearance)
*Please manually uninstall exDialer, the black ics theme, and the xmissedcall patch using an uninstaller with root privileges (e.g. Titanium Backup).
The Lock Screen:
Say goodbye to those ugly sliders! They’re transparent, so their functionality is still intact.
Pin Lock:
Status Bar:
I removed the transparent line in between the toggles at the top and did a lot of color changes.
Keyboard Pointer:
Using my arrow mod:
Now you can actually use your Q or W keys without having to deal with that frustrating keyboard pointer!
System Apps:
Dialer:
The background will always stay blue; it won't ever turn red or black.
Package Installer:
No more ugly gray in the title and bottom bar!
Manage Apps:
Settings:
Pin Lock:
Status Bar:
Keyboard Pointer:
Using my arrow mod:
System Apps:
Dialer:
Package Installer:
Manage Apps:
Settings:
DOWNLOAD:
CTMOD-N00B'ED
2.0 FINAL: Edited status toggle icons, radio buttons, revamped mms.apk, and other notification icons
COMPLETE CHANGE LOG
DOWNLOAD:
Warped Sandwich CT 2.0*
Warped Sandwich CT Uninstaller 1.0 (Return to stock CTMod appearance)
*Please manually change the color of the clock through the settings menu
COMPLETE CHANGE LOG
1.0 Update 1: Changed unknown contact image
The Lock Screen:
Pin Lock:
Status Bar:
Please note that in the image above, I am using Holo Launcher instead of the Xperia Launcher included in the rom.
Keyboard Pointer:
Using my arrow mod:
System Apps:
Dialer:
Manage Apps:
Settings:
Contacts:
Pin Lock:
Status Bar:
Keyboard Pointer:
Using my arrow mod:
System Apps:
Dialer:
Manage Apps:
Settings:
Contacts:
DOWNLOAD:
POSSIBLE BUGS?
UPDATES?
