Everyone,
The baseband borks on those builds because the three modems are not put into the install script. They aren't symlinked to use our modem. Have the dev of the rom u want, to have him resync with cm because the fix was uploaded to cm last night. He should be able to build then and everything works correctly. As far as I know the fix was up streamed last night. It's still currently a work in progress with the lollipop, camera is borked but everything else seems to be working for it. Waiting for all the technical kinks to still get worked out.
Regards,
Sean
Regards,
Sean
peace good people keep up the hard work you guys are awesome. I truely know how hard this stuff is. I'm still new but I try.
your not a triband you are a single band and you will run L710
