Lordvincent 90
Does anyone have the N860V1.O.OB16. zip for the updater tool. Or a link to it. Please and thank you. It would be greatly appreciated. Woodstock took down his multiupload link.
I am a Noob to Android (I'm A Windows Expert) but want to learn. What is a edify_def? Care to elaborate? Well anyways today is your lucky day... I was using the update tool when I came across your thread and decided to HELP so I hurried up and captured the file for you and got it uploaded.. << took forever to upload but here you go N860V1.0.0B19.zip If You Get It Working (Whatever Your Doing) PLEASE SHAREDoes anyone have the N860V1.O.OB16. zip for the updater tool. Or a link to it. Please and thank you. It would be greatly appreciated. Woodstock took down his multiupload link.
Hope This Helps Yall Out. I also have a Untouched Stock Nandroid to upload when I get time to do it.A long time ago bro. And I didnt take nothing down. Since megaupload got busted it got taken down (there is no multiupload anymore). Im reuploading it to mediafire now. In the future if you need something from me just send me a PM. It isnt nearly as dramatic as you think it is. Dont jump to conclusions about me.Does anyone have the N860V1.O.OB16. zip for the updater tool. Or a link to it. Please and thank you. It would be greatly appreciated. Woodstock took down his multiupload link.
I didn't know there were one and the same... Sry. guess you know what they say about assuming...
@AndroidChris the edify_def defines the mount points/preferences for the kitchen to make the updater script functional... *crosses fingers* this could be good![]()
I didnt know either or I wouldve fixed it already. Even though I dont use the Warp anymore I still think its a great phone and would like to see it get more development.I didn't know there were one and the same... Sry. guess you know what they say about assuming...
) would be greatly appreciatedAll that is over my head. SorryNah. Not the same thing... All characters.. Found that last night. Thank you tho.
Do you know anything about setting up edify_def?
I followed the template, compared/corrected vs existing edify_def. It looks correct... i just keep getting status 7 trying to write the boot.img
As a work around i tried it without the boot.img and removed reference to it in the updater script (with intentions to flash it with fastboot) and i get status 6 (error in script)
I tried writing it from the sdcard to the boot partition
Tried pushing it to /tmp
Tried dd command...
is there no way to write to the boot partition?
this is my only roadblock... I have the whole system & framework deodexed (minus email.apk but im trying it with another program tonight)
I have tried about everything but voodoo or virgin sacrifice (saving that for the last resort)
And help or ideas (even crazy ones) would be greatly appreciated
Also, is dev/block/mmcblk0p12 definitely the boot partition?
# The values below should be set in each file in this folder.
# Each file represents a device name (set in ro.product.device of
# build.prop)
# If yes, then this device requires changing the mount point
# names in the new updater-script or update-script
# DO NOT SET TO 'yes' IF DEVICE IS BY DELL
change_mnt=no
# If yes, the device is by Dell and requires changing the mount
# point names in the new updater-script or update-script
change_mnt_dell=no
# NOTE: The update-script will be converted to updater-script if the
# definition file for the device exists. If 'change_mnt' or
# 'change_mnt_dell' are set to 'yes' then the mount names will
# also be changed.
# Mention the mount point names if change_mnt=yes
# Use '\/' instead of '/'
# e.g. sys_mnt=\/dev\/block\/mcblk0p25
# If unknown, set to: ???
sys_mnt=
cache_mnt=
boot_mnt=
data_mnt=
sdcard_mnt=
# Set this mount point for the modem.bin in Samsung devices like the Galaxy S2
modem_mnt=
# Set this mount point if you know what it is (e.g. on Motorola Atrix)
webtop_mnt=
# Filesystem info for SYSTEM/DATA/CACHE/etc.
# e.g. param1=ext3, param2=EMMC
param1=
param2=
# If SDCARD filesystem is different from above, then mention it
# e.g. param1_sdcard=vfat, param2_sdcard=MTD
param1_sdcard=
param2_sdcard=
# If CACHE filesystem is different from above, then mention it
param1_cache=
param2_cache=
# If yes, the device does not require using a 'tmp' folder when
# flashing the boot.img in the updater-script
# e.g. package_extract_file("boot.img", "/dev/block/blah1");
fix_boot=no
# If yes, the device requires a 'tmp' folder when flashing the
# boot.img in the updater-script, PLUS the boot partition name
# needs to be used, rather than just 'boot'
# e.g. Replace: write_raw_image("/tmp/boot.img", "boot")
# with: write_raw_image("/tmp/boot.img", "/dev/block/blah1")
fix_boot2=no
# If yes, the device requires a 'dd' command to write the boot.img
# with: run_program("/sbin/busybox", "dd", "if=/tmp/boot.img", "of=/dev/block/blah")
fix_boot3=no
# Device uses /cache instead of /tmp, e.g. when writing boot.img
use_cache_not_tmp=no
