mooseberry
Is voltage control app compatible with stock rom rooted warp?
You need to be rooted tho its requires su permissions and no the lite version will not allow you to change them i dont think
And be carful not to set values too low or when you try and run some apps they reboot
No problem and i recomended it cuz its what i use and i didnt know if there were free ones on the market
And its not an oc app you need to flash a kernal for that but it causes wifi and blutooth issues and iv heard some occurences of data interuption
And those are my cpu control settings. The settings in screenshots are stable and smooth if you use them i hope you like them
Thanks for your help. Can you point me to other Oc apps that are free and compatible please, buddy
