Root [Boost Mobile] Want to get into making roms
jroderka30
I want to get into making Roms could somone tell me where i could get a good start on reading up and wrapping my head around what goes into making one! Thanks
Yeah your best bet is to start work on the phone remove apps add the ones you want it also on xda developers neroyoung has a guide on how to get setup for building a ROM :D hope that helps
Yea like Apollo said, just delete apps in titanium and then make a nandroid. Use your system folder and boot in the kitchen to deodex and things like that. (DELETE EMAIL.APK BEFORE DEODEXING) just word of advice. and then theme with uot kitchen. Compile a .zip using cwm templates, find the post its easy if you google zte warp cwm template. Thats pretty much how I started. When you get familial you can start to work with code and more advanced things. Good luck, its confusing but rewarding as Apollo and I have said before
A ROM Is what you want it to be so its all that much better you make it for you :D and hey BONUS people like it
