albanymike
Earlier it had been suggested that one clear the cache and the Dalvik cache.
Yeah that did not work or last more then 3 calls? I have all the updates, so I guess I don't know
so is there a way to add notification sounds. I have a couple of sounds that I want to add. I extracted them from another app that I had. I've tried using root explorer and placing them in the proper place system/ media/audio /notificatio? but they don't show up. is there something that I need to do to make them appear
Did you restart the phone?so is there a way to add notification sounds. I have a couple of sounds that I want to add. I extracted them from another app that I had. I've tried using root explorer and placing them in the proper place system/ media/audio /notificatio? but they don't show up. is there something that I need to do to make them appear
yes I set root explorer r/w, you can do anything if you don't. yes I restarted the phone. when I use root explorer the new tones are in the notification sounds but then when I go back into notification sounds on my phone they are not there. I also changed the permissions on the new tones to the same permissions as the tones on my phone and that did not work
When you fix the text issue, you will have a stable ROM that is much better than the stock ROM. I am thankful for your hard work this summer. It has been a learning experience that you will take with you the rest of your life as an example of the kind of work you can do. Be proud of what you have done and accept the humble thanks of so many of us who don't have the talent you do. I look forward to seeing what you do next. Please let us know where we can follow your next project.Alright guys... just wanted tou guys to know that I appreciate all of the support that you guys have given me and I definately appreciate my generous donators in particular HawgHunter... But unfortunately effective as soon as I send out the next ota to fix the text issues... this rom will be temporarily discontinued... I have moved on to another better and more stable collaboration project... I have not completely abandoned this as I do not want to disappoint you guys... but like I said as soon as the text issues are fixed I will move on... there will still be updates with new features but for now... this is the "temporary" end... :'(
Sent from my N860 using Tapatalk 2 Beta-5
I like Swype Beta, but not Swype.
I like it too I really just want to have a blue trace color lol. That's why I ask were there any others.
im using 1.6v i dont have the ota app does this mean cant recieve the ota updates?
I don't use it anymore, but touchpal keyboard has the blue trace that you want.
Thanks bro. ^_^
No problem bro, you try that keyboard?
Yes, I'm typing with it now. I like the blue sparkly trace lol. Don't judge me![]()
Swiftkey 3 is still the best! imo
