Did you hold your power button and check the menu on there? It should have screenshot on there if I'm not mistaken, can't check now my warp is @ the house. Also with the ota update not working did you try my earlier post? Hope this helps.
do another restore but make sure u clear data,cache, and dalvik cache, then flashI keep getting android service media crash. Its random and within 1 minute of bootup. I did a nandroid restore from before it started happening but its still happening. It started late last night and happens about 1/2-3/4 of the time I reboot.
Any ideas?
you will lose all your data. if you have titanium backup, u can restore itIll give it a go.
Will I lose anything important?
I wonder when their going to get done with the CM9 for zte warp.
Has anyone noticed the pattern lock screen is off center? Looks a little strange. Otherwise this rom is awesome, no problems.
I think Jet has gone completely off radar, which is strange, but you know what, I knew he was gonna end up doing that. I can't find the thread for Project Yoshi. The webpage they have is use less.
You have to remember, jet is 17. He goes to school, and plays football. So he won't be on very frequently.
